Hello all...
I just bought my first boat. She is an 18ft Starcraft SS with an 1150 Merc (3367838) on the back. Any way of knowing if this is the original power for the boat?
Anyway I get her home today and she fired right up after I changed the battery. It is missing, but idles and engages forward/reverse and revs fine. Throttle seems to need adjusting though.
Internal harness was just done last year as was the impeller and gear oil. My water stream seems weak running on the earmuffs.
The carbs seem to be a little wet. Do I pull them and replace the gaskets or is a complete rebuild in order. Also the fuel pump might be weak. It died once and I had to pump the bulb because it was empty.
I am not really sure where to start and just seeking some guidance.
Carbs?
Fuel Pump?
Water Pump?
Thanks!
Carbs?
Fuel Pump?
Water Pump?
Thanks!
