71c oil pump R&R
patmilstead
Help I need to change oil pump on 71c velvet drive/
Thanks for any help.
The transmission is already on the bench.
Don S
Re: 71c oil pump R&R
Not sure what kind of help you need, but I would strongly suggest you go through the rest of the transmission and at least clean and reseal everything, and inspect the clutch packs for wear. I can't imagine a pump needing replaced without something else being wrong.
Here is a little help with some manuals. http://www.motoren.ath.cx/menus/velvet.php
patmilstead
There is no oil pressure at lines from tranny. The dipstick reads full run engine for 15 minutess at 1500 rpm nothing at any line or pressure port.
stumped thats why I thought oil pump. Could the pump be indexed wrong on a 71c????
Pat
