Ran good in test tank, took to lake and started ok. Then when leaving dock would not start. Later noticed, will start in gear. That being throttle about half way. Put on trailer and strapped down. Will start in either gear but not neutral. Bring home, put in test tank will not start in neutral but will in gear. Took low idle dog off, so as to, bring throttle up about half way and will start in neutral. Bogs down as I go to low idle and stops, as if out of gas. Took carb off last night and cleaned. This morning, removed flywheel and checked wiring and points. Points set at .020". Cleaned everything, put back together and still have same problem. Will low compression cause this? Have no way of checking compression as of yet. Will have to buy gage. Any and all help will be appreciated. Thanks, Dan
