71' Johnson 85hp. Ignition change to points?
george_sciacca
Can I change from ignition amplifier system to point system.Breaker plate, points and condenser assembly and 4 coil system from electronic box points system and single coil? Box is 270.00 new.Motor was gone through,electric shift L/U new pump and gear case pressure checked.Compression is at 120-125 all 4.
