hi,<br /><br />after running 30 or so gallons of fuel through this engine, i have a few problems. first-- the low speed idle has never been good. it seems to have gotten worse as i have run the engine. i found very excellent directions for the adjustment from Mr. Reeves, but when i went to make the adjustment, it seems as if the carbs have been replaced with a different models. the low speed jets are on the side of the carb instead of in the front of the carbs (as you look at them with the silencer off)... anyway..... now the engine will not start. the engine would always crank right over and start. now it just cranks and cranks..... it will not turn over.<br /><br />then engine has always run perfectly at higher rpms. <br /><br />a gentleman had what seemed to be the very same problem on this board a couple of years back and he finally took the flywheel off... cleanded and regapped his points. fixed his problem. <br /><br />very frustrating<br /><br />crosley
