I have a 1971 Fiberform boat with a Buick I/O that has OMC stern-drive unit and exhaust. It has been stored on the coast for the past 2 years. When I'm accelerating from idle the boat gets up and planes slowly and cruises at 3000 RPM at full throttle for 2-3 minutes and the speed gets up to 23 mph by the GPS. Previous to this problem, the boat has cruised at 41 mph (2 years ago). Also, after that, the boat slowly begins to lose speed and when it gets down to about 17 mph it starts to back-fire. It can then continue to drive at about 1000 RPM for a few minutes (3-5) and after that I can accelerate and the whole process starts over. When I?m going 23 mph, if I back off the throttle to ? throttle and drive at 21 mph (still 3000 RPM) the boat will maintain that speed indefinitely. I have changed the coil and ignition resistor, changed points, condenser, distributer cap and rotor cap, rebuilt the carburetor, and changed tachometer. The distributer doesn?t have a vacuum advance on it. The fuel tank and filters are all new. Temperature gauge stays at 160 degrees. Exhaust port and 2 pee-holes are streaming good amounts of water. I have also checked the alternator voltage while the boat is at full speed and when the problem starts there is no change in voltage (14.2 volts). Does anyone have any suggestions why the loss of power and inability to go over 21 mph? Please help!
