71 120 hp --dad and I --need --- electrical help
wesgmc
our 71 starcraft fib/120hp mercruiser project boat is now in the boat!!!!..None of the wires were marked,, can anyone help with wiring diagrams for this (serial=2731030) PROJECT.. THE ALTERNATOR HAS A RED/WHITE STRIPE --we have the pin connecter plugged in...hah !! there are some wires that need a home ??? if you can help we would thank ya !! ..we (dad and I ) are trying to put a basket case boat back together..We both have the (c) word and this is keeping us busy..ill check this post in a bit
Don S
Re: 71 120 hp --dad and I --need --- electrical help
Click here for a link to the service manual for your engine and drive. It has all the wiring diagrams for engine, trim, and instruments.
wesgmc
thank you don--i am back home and will looking at things.
wesgmc
sir, can you suggest the best way to look at the manual.. i would like to put it on a cd so i can look at it while i am working on the engine ..i have a dell pc with a pentium 4 and XP. It is pretty full up so i have to figure out a way to download it so as not to take up too much space,,, thanks
Adirondack
Just have a blank in your cd drive, and save it to D: drive, or whatever you cd drive is.
Save it to a memory card or flash drive(usb). I have mine saved to an external hd. The CD might get scratched or damaged. If you do it to a cd make 2 so you can file one.
Don S
The first thing you do is save it to your computer instead of just opening it.
Then at your leisure, save it to CD, Flash drive or whatever.
wesgmc
great--i have it and can read it at my leisure--thanks lots
