im having problems with my frankenstein motor its a mix of johnson 25-35 and evinrude housing and botom is the newer 80s type (exhost popeller) mainly most engin parts is pre ekshaust propeller (70s)
ween i get it started it dosent have a tell tell pe streem. the impeller is new and tested with just hand cranking and it works great. (iv tryed and to blow into the copper tube and hold the pee tube closes and then i can hear it gurgeling and it leaks somewere?!?!
iv tryed with a working and with out a thermostat
and the copper tube enters the impeller (iv even driled a hole in the lower unit so that i can confirm theat it enters 100%
i have som other isuse to but im just guessing id have this fixed first. (manly carb adjusting linkage and so on)
any ideas befor i ripp the engin to peasess for the 14 time and try again?
