scottsabre
Thread starter- Joined
- May 3, 2001
- 16
Motor is a 1978, I have rebuilt fuel pump, adjust throttle plate to WOT when at full throttle on control, set the roller on the cam correctly, base timing good, cleaned fuel sys. Adj. highspeed timing 1 degree +&- It does well up to 4500rpm, higher than that it stumbles down to 4300 until I back off throttle some. Still have inch of throttle left that can't be used. Plan to shorten 9ft fuel line and replace bulb. What else? 15ft center console, heavy old fiberglass boat. HELP!!<br /><br />------------------<br />1978 70hp johnny
