70hp johnson tilt/trim
chrisotenn
hey everyone i have a question. i just put my boat on the trailer right out of the lake. the trim is all the way up but it wont go down at all. i turned the screw on starboard side it lowered down. i hit the trip it will go up fine but will not go down at all unless i turn the screw to lower it. is there a fill hole for fluid? and if there is would that be my problem? i would think that if it can raise up it would have enough fluid but i dont know. any help would be greatly appreciated. thank you. oh its a 84 j70tlcrd.
HighTrim
Re: 70hp johnson tilt/trim
Can you hear the electric motor running or humming while hitting the trim down button?
RRitt
most likely a relay. motor failures tend to be in both directions. low fluid fails to lift. Three most likely suspects are bad relay, bad switch, bad connector.
chrisotenn
hey hightrim thank you and rritt for your replys. when i hit the top trim to raise the motor it goes up and i can hear something when i hit the switch. but whe i try to trim down nothing no sounds clicks or anything. rritt if those are maybe the problem do you know where i need to find and look and all those componets. thank you so much for ya'lls help
chrisotenn
hey rritt when you say maybe bad switch do you mean the one on the lever for foward neutral and reverse?
bigbadjim
Check your wiring out of the controller (assuming your trim switch is in the handle) with a test light when pushing the " down button see if you have power, if you do light will light, if not wont, Id try it on the known circut first that works, to confirm that it IS power coming out NOT ground. If it IS a Ground switch then you'll need to find battery power etc. Near key switch. If you have power at the switch - the trim tilt switch then go to the back of the boat and check for power at the motor both directions. If you dont have power there, you may need to check wiring or relays - to motor. Usually you can follow color back to motor for which side your working on. trim tilt motors can either switch polarity or use a second contact in the motor. Process of elimination. Otherwise the Seloc site sells manuals.
chrisotenn
Thank you bigbadjim i will check all this out and let you know
chrisotenn
Thank you all for your help. I found the starboard side relay bad. I went to advance for *****s and grins told the guy i didnt know what car this came off but i needed exact one same polarity and everything. He found the exact relay. I got home hooked it up now it works awesome. So for 12.50 im pretty happy. Thanks again everyone
