turbo4door
- Sep 22, 2012
- 13
Hi,
Desperately looking for some help with our 89 Johnson 70hp.
It came on a 89 Basstracker 17 that we purchased a few months ago and we have been having nothing but trouble with it. It will run fine at idle, but under any sort of load (say, 3000rpm or above) it will run for about 3 minutes and then enter SLOW mode. Have noticed some steam out the top exhaust ports on the back of the motor when this happens.
Here is what we have done so far:
1. Cleaned thermostat (white chunks around it, see next item)
2. Cleaned water jacket on port side of motor. Removed plate where tell-tale nipple was (before relocating it) and cleaned/replaced gasket. Was completely full of scale and nasty chunky white stuff but is now clean.
3. Replaced water pump
4. Relocated tell-tale nipple to top of block.
5. Has newer thermostat spring (updated part, came with water pump kit)
6. Updated temp sensor
Now, the motor has no alarm on it thanks to previous owner, so I'm not sure what tones it is generating (is there a way to hook up something to tell us, say...an alarm horn of another type...12v maybe?)
I really thought we had trapped air in the tell-tale stream but since relocating it today it has been peeing very strong. It would stop peeing before relocating when going into SLOW mode. Will a lean running condition cause this? It happens at the exact same time every time we test. We can put in, get out of manatee zone and throttle up and it dies in front of the exact same dock every time, so I know we haven't made any progress with it.
Not really sure where to go from here? Are there other areas of the cooling system that we need to look into cleaning? Looking for any ideas at this point. Appreciate any help, we are down-and-out over this...just want to be able to enjoy the boat.
