hi guys i have a 70hp johnson 19820model that boggs down under load but only sometimes i,ve replaced fuel, plugs, checked timing,compression. it only seems to do it after a good run at wot. i bring it back to idle then hit the throttle to wot again and it stumbles and either comes good after a few seconds or cuts out. is it time to pull the carbs and overhaul? or poss an ignition problem? any ideas would be appreciated.
