70hp Johnson 2-Stroke 3 Cylinder
ericholder
hi I have a 1977 70hp Johnson two-Stroke 3 Cylinder and need help finding the fuses. i located the fuse near the starter solenoid but can find the other one, if it exist.
There is only one fuse.------What is your motor doing / not doing ?
ericholder
ok, thanks! i had read there were two but could only find one. after replacing the starter solenoid, my starter was still not getting power. the starter is ok.
Check neutral switch in control box.---Check ground wire on the solenoid.
