scout-j-m
- Jul 31, 2009
- 643
I have 94' 70 hp Force. I recently bought it and I haven't done much to it except clean the plugs spray in a little carb cleaner. I have taken it out 3 times so far and have had this problem: I get it in the water and start it up ok, idle out, and take off. It seems to run pretty good but after awhile it begins to cut out, stall, and jerk. I can bring it down to idle or stop and fish for a while and it may or may not be back to normal. My dad thinks it is the top cylinder coil and that it is either bad or has some electrical problem. I can believe this as it seems like its only running on 2 cylinders when its messing up and the jerking/surging is almost like that cylinder is only firing every once and a while. Also, this coil is black and has electrical tape on it while the other 2 coils are a blue/purple color. I plan on doing all the other stuff like cleaning the carb, fuel filter, etc soon. Does anybody know what's going on and why does it run fine when I first go out? Does the engine heating up having anything to do with it?
