70hp evinrude tracker with no compression in one cylinder
mattfor
boat ran great in the fall and then had no compression in one cylinder in the spring, is it possible a ring is stuck?
I doubt it is a stuck ring if it is ZERO compression.-----Amazing how these motors will start and run with major damage to one cylinder.----Pull the head off and I think it will be obvious as to what happened !----Model # is ??
