Bryant Davis
- Jan 8, 2002
- 24
Hello all...<br /><br />I have a 1977 70hp Evinrude that is driving me crazy. I bought the motor about a week and a half ago. Tested compression (140, 135, 135 cold, 130, 130, 125 when warm) and the engine is spotless as far as overall condition.<br /><br />First thing I did was replace the impeller. Took the boat to the lake and it started right up, idled fine but when I tried to take off it bogged and wouldn't accelerate. You could play around and once it got on plane / moving it ran perfectly. My first thought was carbs. I tore down all three carbs, cleaned and put in kits. Went to lake, same problem. Tore down carbs again this time soaking all parts in cleaner for about 15 hours (vs. about 30 minutes 1st time). Also set float levels this time, as I overlooked that in the book first time around. I replaced spark plugs (gapped .40) made sure of fresh fuel, clean fuel pump screen, etc. Went back to the lake, same prob. I did notice this time that while idling, if I put it in gear and immediately run the throttle up, it acts somewhat fine. If I go just into gear, let it idle in gear then try to run it up, it dies. (Also just as a note, it doesn't cough and sputter just acts like it slowly runs out of fuel)<br /><br />I'm about out of ideas. When the boat is idling in neutral, should the timing be exactly TDC on the flywheel? Also when you first put it in gear (idle speed) should the timing remain TDC and then start to advance when throttle is applied? I have tried sync & link, but not sure if I did it correctly. I am almost positive carbs are clean..all orifices and jets clear, etc. The one thing I have not checked is the fuel pump..could the pump cause these symptoms that seem to be just at slow speeds?<br /><br />Any help is GREATLY appreciated.<br /><br />Frustrated for now...<br />Bryant
