bornasfgiantsfan
- Jan 26, 2011
- 3
I have done a lot of work to this motor trying to get ready for some good fishing and other boating activities. I have replaced a failed starter. Removed the LU to replace seals and oil. Cleaned and serviced distrubitor and ajusted points to .014 of an inch. Replaced a bad ignition switch. Replace spark plugs but not the plug wires.
Turn the key on and I have 12v to terminal strip. 12v on blue wire (ignition to CD module). Low voltage to black/white to distrubitor when rotating the fly wheel (11.2v) All with a good ground. No spark, not running.
How can I determine the cause or faulty part. Is it the ignition coil, distrubitor, or CD module. I need a little bit more detailed instruction than the online seloc online service manual has givin me. Any help or guidance is much appreciated. If there is any info that I am missing, please feel free to ask. I will answer any questions to better help.
