Re: 70 Johnson- Thermostat removed
For gods sake man, reconnect that horn! Its you first and last warning, and even that can be too late!!<br />About 90% of engine wear occurs during warm-up. You may not see immediate affects from running without a thermostat, but pull it down in a couple years and compare engine wear. At idle, the engine doesn't produce much heat, so we need to restrict coolant to bring temp up to a safe high.(promoting longevity) Even 140F is low, but we are limited, do to the system being unpressurized. I've put thermostats in engines that weren't speced for them, to prevent fouling at idle. Engines run the longest when they are at a safe high temp. Carbon will form on the piston skirts and eventually score the cylinders if run cold. If the OEM puts them in, there needed.....The absence of them may go undetected if you run WOT all day, but if you idle alot....beware.<br /><br />Oh, by the way, next time it stalls, pull the plugs......are they fouled? If so, your heading in the right direction.<br /><br />As FP says, find a new wrench!! He probably removed his EGR valve from his car as well....LOL<br /><br /><br />Just my humbble opinion.....<br />
<br /><br />Sorry Evin300, didn't see you!!!!!!
