I have a 1986 70 HP Yamaha that I think is overheating. When run at idle for a while, the alarm sounds continuously. If I run a litle faster (maybe 10-12 MPH) while underway for a couple minutes the alarm will stop and the engine runs fine at high speeds. Water is continuously coming out of the small hole in the engine so I know the water pump is pumping something.<br /><br />Any ideas, or should I just change out the water pump and thermostat?<br /><br />Thanks
