bob johnson
- Feb 25, 2009
- 4,306
decided since i had the power head off on this non stop refurbish of my 1988 70 evinrude...Id just pop the head ...worst that could happen is I got to replace the gasket...but it gives me a look and see!
well the lower cyliner looked alike a bomb went off in it..shrapnel embedded in the cycliner and the piston...and it was metal and hard...
so I had no choice but to completely tear it down so i could see if it was the ring or rings...
the motor had obviously been rebuilt...seeing all the extra gasket sealer and the pistons were marked .040. which I found means .040 over size and the bore are 3.229.
well the picton on the underside looks brand spanking new!! the rings look new and both intact on that piston.
the needle bearing on the wrist pin are all there..and look brand new.. the rod journal bearings look new and are all accounted for.
so i am wondering what could have let go to come flying into pieces in this cylinder???
it would have to be small in dia but hard!!..the pieces broke apart...they didnt get bent like soft metal..they broke like a hardened piece of metal.
Also the piston measures about 3.218..is it supposed to be that much smaller than the bore??? i was thinkign it should be within maybe .004 or .005 " of the bore dia!!!
the piston actuall comes up over the deck..but it does so less than the thickness of the head gasket...
there is just a slight bit of scouring on the cyliner walls.. and I can still see a lot of cross hatch from the honing operation...
so what could have come loose in this motor that is available to the combustion chamber?
and it a .01- .011" dia ok for the difference between the piston and the bore???
thanks
hope to hear from you guys
head...
bob
thanks
head...
bob
