70 HP johnson
lovell
Bought with a 70 hp johnson serial no J0021049 model no 65373R what year is it?
OBJ
Re: 70 HP johnson
Hey lovell....that model number turns up as a 1973 Rude 65hp.
lovell
Re: 70 HP johnson
Thanks for the help, but the engine cover says it is a 70 hp johnson. The cover fit the rest of the unit.
seahorse5
Re: 70 HP johnson
The 70 came out in 1974 and the motors look identical to the 65. Are the 3 coils a green color?
rickdb1boat
Re: 70 HP johnson
65373 = Evinrude 1973 65HP 2 Cyl Cover was changed for whatever reason.
lovell
Re: 70 HP johnson
This outboard is three cylinders, the coils are light green. the numbers on the disc on cylinder head is same as mounting numbers. Man at hontoon marina also said the covers will swap with 70hp coversso I have a evinrude 65 HP good deal anyway. Thank all of you for your effort.
