I have a 1983 70 hp johnson 3 cylinder. It was running rough at first so the spark plugs were changed, carbs rebuilt, reeds checked as well as the compression. It runs better, starts and idles fine but at full throttle it just seems to creep along. The linkage seems to be okay as at full throttle the carbs seem to be wide open. Also when you increase the warm up lever the RPM seems to increase as it should. Seems like just when it is under a load it does not run properly.<br />Thanks<br />Martin
