70 hp johnson remove vro pump
hpshadow
1 have a 92 70 i took of vro pump how do i block off and do i use that as my fuel pump?
Jeff_G
Re: 70 hp johnson remove vro pump
Leave the VRO pump on, put a plug or hose with a bolt in it to block the oil inlet to the pump and disconnect the wiring harness to the pump.
kenmyfam
And of course pre-mix your fuel and pump the pure gas in the line out before you fire it up.
