I have an 83 70hp that was doing the same thing. My aunt gave me a 1973 Capri Tri-hull with a 1983 Johnson 70hp that sat for a long time. Got it running with the usual, new tank and hose, plugs, battery. Took it to the lake and did exactly what yours sounds like. After reading these forums, took the carbs off and completely went through them, put in new floats and needle valve and seat, cleaned them up really good. Took it back to the lake and it ran 70-80% better, hardly any bogging out. Been running seafoam in every tank, and now it is 100%. I would definitely look at your carbs, and replace the fuel lines to them if they are 1984 vintage still. I would also refrain from starting spray, if anything, use a spray bottle with some premix fuel.
