Hi, I have a '89, 70 hp johnson VRO. It will start fine and run fine for a few minutes at WOT. Then it starts cutting out and eventually looses power but doesn't stall. Other times it will run fine for the warm up period, then when I'm ready to pull a skier and give it full throttle it just bogs down. I shut it down a leave it for 1 hour, it starts and then runs perfect for the rest of the weekend. Sometimes it runs perfect without it having its little "bog down/rest period", so I don't think it is an overheating issue. I have 2 portable gas tanks and they are vented properly and the problem happens with either tank. If it was sucking air or the carbs are gummed up wouldn't it run poorly all the time? I've checked the plugs after "bog down" and they are dry, like its not getting fuel. Also checked the fuel filter and it is clean. Could the VRO system be causing this intermitent problem? I'm thinking of disconnecting it and just mixing my own gas just to see what will happen.<br /><br />All suggestion appreciated.<br />Thanks
