70 hp Johnson compression
53150
I did a compression check on my 1980 johnson 70hp. The top two cylinders read 130# and number three read 125#. I pulled the head off too inspect the cylinders, and number one and two have some mild scoring(just enough to catch my finger nail). Do I need to correct this situation now or wait until boating season is over. The main reason I'm asking is because the compression seemed to be good. <br /><br /> Thanks for the advice<br /> Will Vaughan
Hooty
Re: 70 hp Johnson compression
The compression is good, Will. I'd button it up and maybe check it again next year. Meantime, run it like ya stole it.<br /><br />c/6<br /><br />Hooty
OBJ
I wuz about ta post nearly the same thing untill something popped up here at tha house...namely the cat that's been gone fer a week and a half.<br /><br />Shoot Will, with that kind of compression, I wouldn't have given it a second thought. Cylinders running 5psi off aint bad. Maybe decarb it and run it, as Hootymeister says, like ya stole it.
53150
Thanks for the advice guys. Thats what I was hoping to hear!
