70 hp force help
5string
I just put this 70 hp force outboard on my 17.5 foot polar skiff, fiberglass cc. I took off a good running 1996 Johnson 48spl. I took it out on the water and it ran OK, it was surging just a little going out but coming back it was fine BUT. The reason I made the change was I was having trouble getting the boat on plane and when I started the motor to come back I was in a descent outgoing current maybe a mile from the inlet and it wouldn't plane. I cruised slow till I got closer to the dock and then it planed just fine. Sometimes the motor puffs or sneezes when I first start it like it missfires or something so I'm going to check the timing and clean the carb. One thing I wonder is going from a 50hp johnson to a 70 hp force should be a pretty noticable hp increase and I would think it would get on plane better? Any suggestions and I'm also thinking there might be water in the hull even though none comes out when I pull the lower plugs to drain it. I have owned the boat for about 6 years and never had the planing problem till last year. I had it in the shop and the mechanic said one carb was bad so he found a good used one to put on it but it still wouldn't plane sometimes so I put this motor on hoping it would be better.
5string in NC
jerryjerry05
Re: 70 hp force help
Do you have a tach? What does it rev to at wot?Is it proped correctly?You have a spare prop?If so is it the same pitch?If it's different change it and see if the performance is the same.Lower pitch will increase rpm and possibly help get it up on plane faster.J
john from md
Do you leave your boat outside and uncovered? If so, it may be water logged.
John
