The iboats forum moderators are excited to announce that at this time it appears the iboats forums posting pictures function is working once again. Though we cannot promise for how long, we're hoping for indefinitely.
Howdy MBooher.<br /><br />Steelspike is right, fuel problems can cause that, but more often it is because the engine is running on only one or two cylinders.<br /><br />Short out each plug with the engine at idle. If a plug doesn't cause a drop in rpm that cylinder is dead.<br /><br />Check for spark on any dead cylinders.<br /><br />Got a dead one with good spark? Squirt a bit of fuel into the carb for that cylinder and see what happens.<br /><br />All cylinders making power at idle? Go to Steelspike's advice.<br /><br />Let us know what you find.
