Problem: 20amp fuse blows when using the power trim going up only, whether at throttle handle or on engine. Power trim down works and does not blow the fuse. Sounds like a short?
Yep, those are the relays. Fuse blows due to too much current draw so 1st step I would take would be to clean and inspect all wires and tighten them with a wrench. Look for pinched wires. Green wires are for down function, Blue wires are for up.
