70 horse 2 stroke johnson not pumping water
redscolt
I have an early 80s johnson 70 outboard that dont pump water Impellier is good and turns with shaft.fires rite up .I put ears on it and even took it to the lake and still not pissing water.that little thing on shaft to hold impeller is there.Any help would be great
Snowfish
Re: 70 horse 2 stroke johnson not pumping water
Last season I replace my water pump only to find out the Tell Tail line was plugged!:facepalm:
With the ears on, and running, ream the tell tail hole with a wire. You may have to pull the end to really clean it good. Algae and crud can plug it up pretty good.:eek:
divinginn
I have had mud clog up my tell tail,try cleaning it and check your motor to make sure it is not overheating. A paper clip works good for poking it in the tell tail.
redscolt
I took out lower unit and put high pressure water up the tube and it did not come out the holes in back I did this with the motor running briefly and with it shut off, Now I am lost
mark1961
Ensign
Its normal not to have water coming out the exhaust reliefs under these conditions (thermostat closed).....however, if there was none from the telltale check its plumbing for blockages.
