7.5 Sea King ie-Clinton
rogham
I got this for free, Montgomery Wards Sea King 7.5 hp, Clinton Model: K7503107 D Serial: 998113<br />Type: XTV52207<br /><br />I have not tried to run it yet,<br />1. Can I get a manual?<br />2. Can I get parts?<br />3. What year is it?<br />4. From a previous post I understand this type motor is air cooled and runs on chain saw 2-cycle engine oil/fuel mix?<br />5. Generally speaking, is this motor worth the effort or should I just give it to someone else?<br />Thanks!
CATransplant
Re: 7.5 Sea King ie-Clinton
There's an after-market manual that covers all the off-brand small motors. I can't remember the title, off-hand.<br /><br />Parts are a bit tough on these. You can sometimes find carb stuff at a small engine repair shop. Other than that, it's not easy.<br /><br />You're correct on the type of oil....mixture is either 16:1 or 32:1, depending on year, and I can't tell right away what year yours is.<br /><br />If it runs, it's great. If not, then you're in for some work and parts hunting. These are not all that valuable when they are running, so keep that in mind.
rogham
Thanks for the info!<br />I determined that its a 1969. I got it to run, but I couldn't keep it running. I think the carb is gummed-up from sitting. It has good compression and spark.<br />I plan on giving up on it.<br />If anyone is interested in such a motor... pass the word.
CATransplant
Too bad...you can probably get it running again with a little work to clean out the carb. They're not terrific outboards, but they will do the job.
pdreising
Originally posted by CATransplant:<br /> Too bad...you can probably get it running again with a little work to clean out the carb. They're not terrific outboards, but they will do the job.
pdreising
if you still want to get rid of that motor, let me know. i also inherited one and the linkage for the tiller throttle is broken
eBay has Ted Williams Manuals, etc. up right now. 10.00-20.00 or so. Just search them over and over. Good-Luck! Terry Tennessee
