Hello again,
I am curious as to what you guys do when you shut down an old motor like mine or similar at the end of a run. I have the pressurized tak and it works well. I have been turning the tiller arm control to stop as I come in to the dock. The motor shuts off as expected. I then loosen the cap on the tank and let the pressure off. Then I disconnect the tank and store in my vehicle for tthe trip home.
In the morning, I have found a small gas stain on my driveway and have determined that the fuel is coming back through the fuel line from the carb bowl and is dripping from the male fuel metal intake line.
Is there a way to shut down the engine so as to clear the fuel line and bowl of fuel to prevent this overnight drip. It is a small amount but it does stain the ashphalt.
Perhaps there is a small cap I could rig to slide over the male fuel intake metal fitting to prevent the drip overnight. Or maybe a better shut down procedure would solve the problem.This is just a gravity issue and not a serious leak[I think].
So how do you guys deal with it? Looking forward to your insights.
Thanks,
Sean.
Thanks,
Sean.
