7.5 hp Evinrude exhaust cover bolts
old one
Removed the exhaust cover from an 82 7.5 hp Evinrude to fix a water pumping problem. I noticed two of the bolts are shorter than the other four. Correct installation location? The center two?
D
DJ
Guest
Re: 7.5 hp Evinrude exhaust cover bolts
old one,<br /><br />Not sure, when I run into this dilema, I stick a toothpick up into the bolt holes to see which ones are deeper.
old one
Thanks for the advice. With the exhaust cover on I will try the depth measurement.
