Re: 7.5 Honda (B75)
If you look carefully at the top of your cam pulley you will see a dot, and if you look even more carefully at the engine case between the starter and that pulley,you will see a similar looking dot.Then ,on the side of the flywheel, you will see a line ,or sometimes two,but one will be stamped with a T.Remove the pull starter and line that line up with the rear boss of the starter mount.All three should line up or the one cam pulley dot should be 180 out.If so then give the flywheel another turn, then all should line up.If not ,valve timing trouble.If so , tight valves?Crappy fuel?Exhaust leak?
