7.4GL Fuel Pump???
Ontherox27
I have a 1996 Volvo penta 7.4GL (carb) and noticed a whining sound almost like a power steering pump with low fluid. I've seen a lot of post describing this whining to be a bad fuel pump. I recently went out and my boat just shut off. I was able to get it started again after pumping the throttle several times and leaving it down half way. I got underway and ran fine then shut off again. After cracking on it and doing the same process I was able to get it started and back to the dock. Is this a typical symptom of a bad fuel pump? If so what Fuel pump do I get? I just see the High/low pressure pumps, and mine only has one pump. Thanks for any help....
jerryjerry05
Re: 7.4GL Fuel Pump???
If??? You have the electric fuel pump?
It's possible the pump is bad.
Hope not cause they aren't cheap.
Try do a pressure test on the pump.
Not sure of the specs.
The units with 2 pumps are for the injected models.
Before you buy, make sure there isin't a clog in the filters or pick up.
