Hello all-have been having rough running issues pop up on my Maxum 2800SCR.
Suspected the fuel pressure regulator (mounted below motor down on the fuel cooler), but when vacuum tube disconnected found fuel leaking out. The top regulator/fuel pulse damper is leaking fuel freely, I assume this is not normal? I cannot find this top regulator on any parts lists, any part number or info greatly appreciated. This is the regulator/damper mounted up top of the motor, tees off from the tube going from plenum down to the bottom regulator.
