Re: 6hp Power Outlet Wiring
Hi Ray,
Just realised that you are in UK, didn't notice that last night!
Yes you have interpreted the diagram correctly.
Silicon diodes of a suitable rating. but I'm not I'm quite sure what. You dont have a Radio Shack in Staffs, & Tandy UK disappeared years ago. Maplin may have something, alternatively RS Components. They are going to have to be rated at least 5 amps, 50volts PIV will I think be adequate. On that basis P600A from Maplin I think will do or P600D which is 200V PIV.
Don't be short with Tashasdaddy though. He's one of the top dogs on this forum! His answer is correct.
You should be able to get an OEM manual from the US if they are available. Ken Cook is often quoted for manuals, or the people TD suggests. Maybe TD can advise on that score. Clymer and Seloc manuals are not rated very highly, putting it mildly! The folks in the US dont realise how difficult it is to get OMC stuff in the UK, or any outboard stuff for that matter.
In the UK Wills Marine in Kingsbridge Devon
www.Willsmarine.co.uk are good for mail order spares. maybe they can help with a manual!
Alternatives
www.outboards-direct.co.uk (Oakley Marine in Brighton) and
www.outboardservices.co.uk in Lostwithiel.
The idea of the rectifier is to convert the AC to DC for battery charging but I guess the stator (still surprised one is fitted on a '75 model) is only rated at 5A but you only get that at high revs so battery charging may be rather disappointing. I have also fitted a small solar panel to augment it.
Reckon your motor is a European , Belgium, made one because the number does not come up on the BRP parts website.
Best boating forums in the UK are the
www.ybw.com/forums forums run by IPC Media, Practical Boat Owner, Yachting Monthly etc. i Boats still tops for outboard advice though.
Good luck sorting something out, hope it works. I wont be around for a bit, should have gone into hospital today but the state of the local roads and the rail services into London have forced a postponement until tomorrow (fingers crossed) PM me here, or better via YBW, if you want but I'll only be able to reply at weekends for the rest of this month. VicS on YBW, no dot before the S.
Leave you with a picture of an '84 6Hp Yachtwin on my boat
