Re: 6HP evinrude fisherman 1972
Welcome to Iboats, Mr. Taylor!<br />Make sure one of those wires that are coming down from beneath the flywheel aren't shorting to ground somehow. Disconnect them from the kill switch, etc.<br />The next most likely reason you're not getting spark on the top is a bad ignition coil. They're known for cracking and getting water in them, or letting the spark out.
<br />Then points and condensors.<br />Then spark plug wires.<br />Fortunetly, new coils are cheap and available. Even NAPA autoparts sells em. If you find one coil bad, replace both. It's age that causes them to crack.<br /><br />You can get an aftermarket manual here at iboats (just click 'Manuals' below), or you can get a reprint of the OEM one from
here. You're really going to want a manual for fixing your engine.<br /><br />The flywheel is keyed to the crankshaft, so you will not change the timing simply by removing it. But you will need to adjust it if you remove the points. The flywheel must be removed by employing a puller that uses the three screw-holes in the top of the flywheel. If you use an edge puller, it will break the flywheel. An automotive 'harmonic ballancer puller' will do the job well.<br /><br />Good luck!
