6hp 2000 4 Stroke Nissan Outboard Fuel Leak
latitude22
Hey guys got a quick question, just picked this up today, been sitting in a guys garage for quite sometime. After starting it I realized fuel was pouring out of the carb, all over the thing top to bottom. It appears that the carb has been removed in the past as the screws are obviously scarred up a little.
My question is, is this most likely a gummed up carb or is it likely something else is wrong and I need to order a replacement?
Thanks
pvanv
Re: 6hp 2000 4 Stroke Nissan Outboard Fuel Leak
Time to clean the carb. Likely a jamming needle.
Mas
Sounds like the float is not seating to shut off the fuel when the bowl is full.
MAS
TOHATSU GURU
Floats don't seal anything. They raise and lower the needle....The needle is stuck.
Mas
Yup!
MAS
