I replaced the impeller and water pump housing and put everything back together seems as if after it warms up (on the muffs) it wants to idle way up after it warms up...and then it will die, if you go and squeeze the primer bulb its soft and gas will come right out of the carbs. Not for sure what to make of it? Also I replaced the impeller but it still isn't peeping, I ran a piece of wire into the tube and it was clogged, but it still isn't peeing... I haven't had it in the water yet I thought maybe it was just because it was on the muffs. I appreciate your guys help.
