69Alumacraft
- Apr 1, 2010
- 7
I have a 1969 Mercury 1000 (100 hp) that has the #1 cylinder with compression around 90 psi and the other 5 are around 120 psi
. We poured a little 30 wt. oil into the cylinder and that brought it up to about 115 psi.
The boat hasn't been run in a year when I had problems with it bogging down and dying on me (1969 Merc 100 not running under load). Could this just be a problem with not having run it in awhile and the top cylinder didn't have enough/any oil? Would we get more consistent numbers if we ran it for awhile on the hose and then checked?
I know nothing about 2 strokes, so I'm sure where to proceed from here. I live in the middle of the Mojave and there aren't any marine mechanics in the area. Would this be something that a motorcycle mechanic could work on (since, I assume, a 2 stroke is a 2 stroke is a 2 stroke)?
Any guesses on what it would cost to fix?
