sstrudell
- Aug 7, 2006
- 11
I recently pulled my prop and bearing housing on my 69 Johnson 55hp outboard. I was getting water in my gearcase so I replaced the O ring on the bearing housing, put new seals on the screws that attach the bearing housing to the Retainer plate and replaced the washers around the oil screws.
Everything came off easy and went back on pretty easy as well. Only thing I had to do was tap the bearing housing back in a bit, but no excessive pounding.
Except when I went to start the engine and there is no neutral. The prop is spinning with the throttle in the neutral position. It spins faster when I put the throttle into forward position.
Not exactly sure what I did, because I didn't touch anything beyond the bearing housing or the retainer plate.
The boat was running well before except for the water in the gears.
Any ideas?
Any ideas?
