69 Johnson Seahorse 33 Electric - plug reccomendations
Vdub144
I tried searching on Seahorse, and didn't see this addressed in the 200+ posts. :p <br /><br />I acquired a 69 Seahorse 33 over the weekend. It was running rough during test drive, so I pulled the plugs to take a look. The bottom plug was loose. Neither was *significantly* fouled, but didn't look "new" either.<br /><br />The manual suggests J4J plugs. The top cyl was running a J8J, and the bottom a J6C. Nobody in my small village (hardware store, NAPA, two marinas) was open over the weekend to get new plugs. (The hardware store was, but didn't have J4Js - not even listed in the Champion cross reference book! :confused: )<br /><br />I cleaned and replaced the plugs. About 10 minutes up the river I hit a rock and my pontoon started running rough. Touched top wire, all OK. Touched bottom wire, shocked :eek: The bottom plug had snapped in half! (Old plug? Hairline crack?)<br /><br />Limped back home, then pulled another J6C out of an old non running 'Rude in my garage. Put it in, and got running again. Trolled up, watched the sunset over the marsh (incredible :D ) and then back home.<br /><br />On the way home, my neighbor *blew* by me in his much newer pontoon with Merc 30. (I was half his speed!) I could pull either plug wire and keep the motor running on 1 cyl, so I know both were firing. (I believe my ponts are galv steel, while his are much lighter aluminum.)<br /><br />OK, way too much detail now :rolleyes: My questions: what is the correct plug to take the place of those J4Js? Is the J8J hotter? Or is it just the 'intended use' of the plug that differs? (i.e. 8 = snowblower rather than 4 = marine?) What about the J6C? Is this a 'direct replacement with updated part numbers' or the previous owners have just found that J4Js weren't hot enough and this is conventional wisdom?<br /><br />While I don't LACK power, I probably should be getting more than I am. Once I'm up to speed, there shouldn't be as much difference in the two boats - just the amount of time it takes to get the extra weight up to speed. What can I do to look at this? (A new prop is likely my first order of business! Admittedly the one on there is pretty carved up.) <br /><br />One additional bit of info, I do have more than what I consider an acceptable level of oil/gas in my exhaust/cooling. (I can see it on the water when idling.) I also see it if I manually tip my outboard out of the water. (I don't have power trim.) I'm not 'dumping' gas - I've had that happen with another motor when one cyl quit working altogether - but it is more than what I think it should be. (And I don't want to pollute the river.)
Vdub144
Re: 69 Johnson Seahorse 33 Electric - plug reccomendations
Impatience got the better of me. Rather than searching on Seahorse, I searched on J4J and now am going to answer my own post. (Since I read lots of other people's posts to find this answer, it makes sense to put it in one place.)<br /><br />Turns out J4J is a common plug - and has been updated to J4C instead. A J6C is hotter, and a J8C is even hotter. A hotter plug reduces fouling, but increases the chance of head and piston damage. :eek: Common wisdom seems to be to swap in the J6C for the J4J to reduce fouling, but maintain a reasonable running temp.<br /><br />Of course, since I spent the last couple hours researching this, I haven't tried it yet - nor have I replaced them, the wires, the condensors, points, etc. Hopefully that will help me run 'cleaner' if not a bit leaner. :)
