'69 Johnson 55HP losing spark occaisionally
strucksteve
I just Bought a 1969 Johnson 55hp hydroelectric shift. it starts and runs great everytime at the launch. It will completely stop running intermittently. I've been told that it may be the condensor heating up. i'm looking for a schematic and advice. it usually runs long enough for each person to get a run in skiing, but lately we;ve been getting cut short. it usually won't start right back up, but sometimes does. i've wiggled all the wires three times each while it runs good, so i think it's not a loose connection. the wiring harness is brand new with all soldered connections. thanks
Joe Reeves
Re: '69 Johnson 55HP losing spark occaisionally
Steve.... That engine has what is called Battery Capacitance Discharge ignition which is capable of haveing the powerpack fail in a intermitent condition.... now it works, now it doesn't.<br /><br />The powerpack can be tested, if you can get the engine to cut off and stay that way (won't start) for awhile. The test procedure follows.<br /><br />(Battery Capacitance Dischage Powerpack Test)<br />Various OMC Engines - 1968 to 1972)<br /><br />Purchase a small 12v bulb at your local automotive parts store (the 12v bulb is to look like a flashlight bulb, not a headlight bulb). Solder two wires to that bulb, one to the side of the bulb (ground), and the other to the positive point. <br /><br />Remove the spark plugs. With the key in the on position, make sure that you have 12v going to the pack at the terminal block (purple wire).<br /><br />Now, connect the ground wire from the bulb to any powerhead ground. Connect the wire from the positive point of that bulb to the powerpack wire that is connected to the coil wire on the terminal board (blue wire). <br /><br />Crank the engine and observe that bulb closely (CLOSELY!). If that bulb glows even the slightest bit, the powerpack is okay. It may be a very dim glow... just so it glows! If it doesn't glow, the pack has failed. <br /><br />Keep in mind, that type powerpack (Battery Capacitance Discharge) demands a top notch battery of at least 70 amp hours. Any less will, in time, cause powerpack failure.
strucksteve
thanks joe. can i use a standard 12 volt test light?<br />if the power pack checks out OK, then what next?<br />if the power pack has failed, is it the power pack, or something else affecting the power pack?<br />also, how can i check the battery amp hours?<br />the owners manual states that the motor can run off a weak battery(that is assuming the charging system is good)<br />the battery seems very good, as it can crank the !@#$%! out of the engine for quite some time as it is not firing.
Mikko
Dear Captain,<br />I have 1969 Evinrude 55 Triumph (electric shift) and same problem already 15 years. Pack and coil both tested ok, but I heard that it could still be the coil and cooling the coil could help. New coil is about 60$ here in Finland. Be sure that battery is strong enough otherwise it won't start. I did not run my motor at all last summer but in 2001 it was still ok. Now it did not start at all??? I have not changed the coil yet.<br /><br />Mikko
