69 johnson 40 problems
bdubious
I have a manual shift johnson 40 hp from gulp, 1969! Runs for a while with little power then dies. Never to start again. Now it won't start at all. I hear clicking coming from the choke solenoid (not the starting solenoid - I just replaced it) and it will not turn over - however it will turn if I boost the starter with a live 12v wire. It clicks when I turn the key to start and it clicks when I push the choke button in. Could this be a bad choke solenoid or some other integral part, maybe the switch? Ready to go fishin but stranded!<br />thanks for any help.
JB
Re: 69 johnson 40 problems
Try "Outboard wont start" in FAQ, Bdub.<br /><br />Good luck. :)
meandmygarform
maybe your keyswich is bad had the problem with my motor key swich was shorting out test the keyswich it,s and idea anyway
Paul Moir
When you've got the starter working again try running the engine on one cylinder to see if you can isolate the problem to a particular cyl. Just disconnect and ground out the other spark plug lead. If it won't start, check spark. Both leads should be able to draw a nice 3/8" long spark.<br />Does the primer bulb get hard? What do your spark plugs (firing end) look like? Does the choke plate stay closed while your running?<br /><br />PS - '69 is hardly even considered old around here. I see my '72 engine as downright modern. :D
