69 Johnson 40 hp electrical problems
bdubious
I am restoring a 69 boat and Johnson 40 hp - I have the motor working fine, however, I replaced a switch to the nav lights (I thought) and have run into a problem. This motor is set up to have an electric choke. One wire to the ignition and the other ground (I thought). I turned the thing over and the supposed ground wire caught fire. -oops. With that wire disconnected nothing happens when I turn the key. Afraid to do anything else until I get some adveice. Can anyone direct me to a colored schematic for this set up: that includes wiring for a ammeter, choke, overheat warning light, ignition, nav light switch. Or just tell me where the other choke wire goes. Thanks
JB
Re: 69 Johnson 40 hp electrical problems
You need a Repair Manual before you mess with it further, BD.<br /><br />check here: http://www.boatmotors.com/manuals.html <br />or get an OEM manual from www.kencook.com.<br /><br />Or you can just borrow one from your library.<br /><br />Good luck. :)
Joe Reeves
Assuming all of the wires are leading from the engine/instrument wiring harness, what color are the wires?
