'69 85hp Johnson Choke,Starter,Rough Idle - Stalls
robvanv
I just got a 1969 85HP Johnson #85ESL69M and have a couple of questions: <br /><br />CHOKE: Should the automatic choke solenoid draw current when: manual choke lever is in AUTO, key is ON, choke switch on dash is OFF, forcing the solenoid plunger up (choke OFF)? It gets quite hot. The choke has been Stuck ON (plunger down with the dash switch OFF) a couple of times causing the motor to flood - I'm just using manual choke for now and wonder if I should replace the choke solenoid? <br /><br />STARTER: The gear on the starter that engages the flywheel (bendix?) seems to disengage very prematurely at times not allowing enough time for the motor to fire up and start. Seems to be more evident when the engine is warm?? Is this normal? What causes it to disengage - certain RPM? <br /><br />IDLE TROUBLE: When cold, the engine is a bit hard to start but it starts. It idles a bit rough (shudders a bit sounds like its missing). When you give it throttle and get cruising it runs great. But, it seems once it was warmed up it will not idle - misses even worse at idle speed and will stall out. Then it is hard to start but once it starts it will run well at speed again but will not idle if warm. It has a new amplifier assembly and a recent compression test shows (130,130,128,120). Where do you think I should start? Ignition or Carb?
Spidybot
Re: '69 85hp Johnson Choke,Starter,Rough Idle - Stalls
The starter gear is disengaged once the flywheel runs faster than the starter motor. So if it fires and kicks the mechanism thinks it running and will disengage. Purely mechanical.
