Re: 68 voltage suppressor source? or deleting from system?
The suppressor, and clipper do basicly the same thing, they protect the system from voltage spikes, or loose connections. As long as you use a good battery, and maintain all tight connections, you can do with out it. You simply remove it, and go directly to the coil from the pulse pak. For some reason, the coil is called a pulse transformer on this system.
