'68 V-4 85hp Johnson w/electro-matic shift firing order
bonue1
'68 V-4 85hp Johnson w/electro-matic shift<br /><br />what is the fireing order,I think it is 1234 ,has the the cap under the fly wheel.runs good from 0 to 1/2 throdel and then starts to cut out,backing down to 1/2 again,starts running good again.new coil,plugs,wires.I found that it is running on 1 and 2 ,<br />But not running on 3 and 4.All wires are fireing. commpresion is at 85# per cycl.Help?
