Hunting Fred
- Oct 12, 2013
- 2
This is about a 68' I believe mercury model 60 (6hp). Approx 2 years ago or so, carb was rebuilt by a local shop because motor didn't really want to idle or rev up without dying.
Long of the short is, after carb rebuild, it ran like a dream on a few lake trips etc. I then garaged engine for about two years and decided to pull it out again to use on duck hunting boat in Ca Delta.
Engine will now only run about 20 sec or small variances of such after primer bulb is pumped to firmness. After which time it will shut down with haste (no sputtering or dieseling). Motor will run at idle, high rpm, and in gear with primer bulb pumped to firmness. Engine will also run (tested for more than 5 min) if I continue to pump bulb.
I suspected a fault in bulb or hose so I replaced both with 5/16 hose and a Merc bulb. Same issue still exists.
Is my fresh carb rebuild shot again because of storage? Does it sound like maybe a fuel pump issue? As far as I know the fuel pump hasn't been serviced ever or for at least a LONG TIME. Any advice and ways to test for leaks, fuel pump failure, etc is greatly appreciated! I need help please! Carb rebuild had less than 15 hours on it prior to storing.
